2. Reduces manual data entry
7. Scales with your business
What is Ragic?
- ● Set up fields like:
1. Product ID: You can set this as an Auto Generated Field, with customized format as you want.
2. Product Name
3. Category (use Selection Field that will show up like a dropdown menu for faster input)
4. Image
5. Current Quantity
6. Minimum Stock
- ● Save the design.
This relationship between two sheets setup is as easy as connecting dots between two fields, no VBA, no complex scripting.
Here’s how:
- ● In your Outbound sheet, Go to Form Tools and choose Update value on another sheet action button.
- ● Set the Inventory sheet as the target.
- ● Select Outbound Quantity as the value to deduct.
- ● Set the operation to minus (-).
- ● Select Current Quantity in the Inventory sheet as the field to update.
- ● Add a condition so that the stock is only deducted when Product ID in the Outbound sheet matches Product ID in the Inventory sheet.
You’ll now see the Deduct Stock button and a Reverse Deduct Stock (You can rename the button after if you want) button appear in the lower-right corner of your form.
- ● Create a new outbound record.
- ● Select the product and quantity.
- ● Click Save.
- ● Hit the Deduct Stock button.
Boom—stock updated.
The Stock Deduction Time field will auto-fill with the exact time you clicked the button, and if you check your Inventory sheet, you’ll see that the quantity has been adjusted accordingly.
Here’s how:
- ● Go to the Design Mode of Inventory sheet
- ● Choose Form Tools > Show references from existing sheet.
- ● Select the Outbound sheet and choose the fields you'd like to display—such as Outbound Date, Quantity, Destination, etc.
- ● Insert the subtable, then Save and Exit Design Mode.
- ● Add a new field—say, “Below Min. Stock?”— and set the field type to Checkbox.
- ● Then use this formula: IF(D3 > D2, 'Important', 'No')
This means: if the Minimum Stock (D3) is greater than the Current Stock (D2), it’ll return “Important”, which triggers the warning icon. Otherwise, it returns “No.”
Scan barcodes, tap Add Stock or Deduct Stock, and update things on the spot, right from your phone.
Category: Applications > Use Cases
